HAL needs to get detailed port information before it can add the static FDB entry for the port. However, something went wrong and it failed to get the port information.
Remove the port from the vlan and readd it. If this still fails, delete and re-add the vlan.
Error
Getting port info has failed while adding static FDB entry for vlan %vlanId%
| Name | Type |
| vlanId | VLAN-tag |
